Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
How to add sequence number in drawing list
jayartadle
Message 1 of 11
jayartadle
Is there any way to add sequence number in drawing list thru sheet schedule. I want to see also how many sheets are there. Thanks!
Replies (10)
Message 2 of 11
David_Knight
I think you'd be able to create parameters for each set.  then set them to Yes/No.    There would then have to be a second formula parameter for each one that basically said something like If SD = YES THEN •
Message 3 of 11
David_Knight
Here is the solution.
Message 4 of 11
Do you want count total sheets for each issuance?  If so, add a yes/no parameter for each issuance (i.e. SD, DD, CD), then add a calculated value parameter for each (SD Count, DD Count, CD Count) with formula and calculate totals:
SD Count: if (SD, 1, 0)
DD Count: if (DD, 1, 0)
CD Count: if (CD, 1, 0)
Message 5 of 11
RDAOU
First Question:
Yes...Add a project parameter to sheets (Instance/Integer) >>> Add that as a field in the schedule >>> then
  • Either Fill it manually for each sheet
  • OR use Dynamo to generate a sequence and fill that into the parameter you created above
Second Question:
You could simply go to the SOrting and Grouping Tab of the Schedule
  • Set totals to show in the footer of the Discipline
  • And check the box for Grand totals to show total of all sheets
Message 6 of 11
jayartadle
Thanks for the answers. Is there a way to make it like this in the image below.
Message 7 of 11
RDAOU
@jayartadle
Yes as stated in Message 5 above...and as detailed in reply to your question HERE
Message 8 of 11
jayartadle
Thanks! Great Help!
Message 9 of 11
johnericsons
Hi @RDAOU, I'm having the same problem as this one but mine involved linked files.
I'm creating a sheet list on one main file and the other models are linked there sheets on every link. I did create a nice sequence as shown below, the only thing that's missing is the sequence numbering so I tried finding ways to solve this and came up here on this thread.
I tried using your dynamo script but it doesn't work the way it should be. Maybe because the sheets are on the links? I don't know if this can be solved by Dynamo.
Thank you
Message 10 of 11
hliS658H
I am referring your schedule file, but the project parameter I create is grayed out, not sure how to change that?
Message 11 of 11
Richard_BIM360
 Yes, in schedule need this Number sequence. please share to us. Thank you
