How to add numbering in drawing list
2 REPLIES 2
jayartadle
2396 Views, 2 Replies
I want to add numbering to my drawing list to identify how sheets are there in the project. Please see the Drawing listDrawing listimage below.
2 REPLIES 2
RDAOU
in reply to: jayartadle
@jayartadle
Isn't this the same question you have asked yesterday here --->> How to add sequence number in drawing list - Autodesk Community - Revit Products
Nonetheless, here is how again...
  1. Add a project parameter to sheets (Integer/Instance)
  2. Add to the schedule as a field
  3. Fill in the values
    • Option 1: Manually for one sheet after the other
    • Option 2: Use Dynamo to fill them automatically
  4. Sort Sheet list using that sequential number
RDAOU
Dynamo file attached...Download >> move to Dynamo Player default folder >> run it everytime you add sheets and it will update the sequence/running number . see screencast below how to use.
I am using a second graph to add sheets (that one is irrelevant to your exercise)
