How to add labels to components to be visible on print
Hi Viveka and community
Can anyone tell me how to add labels to components so when printed it can be seen
Sahay_R
Are you trying to add labels to the component family? What exactly are you trying to achieve?
Since I don';t know what exactly it is that you are trying to do, one of the two should work -
In the family -
1) Create a label
2) Nest a generic annotation family
3) Sometimes the simplest approach is the most effective - just create a piece of 'dumb' text
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Viveka_CD
Hi @Anonymous
I see that you are a new visitor! Welcome to the Autodesk community! Smiley Happy
As @Sahay_R mentioned you can try nesting generic annotation families inside host model families so that the annotations appear in the model.
This is useful if you want to include a label with a model family and display that label in the project, which I assume is what you are seeking.
  • Generic annotations hosted by the model families scale with the view when they are loaded into the project. When you place these generic annotations on a sheet, they display at the same size, regardless of view scale.
  • For example, a 3/32'' text label in a model family always prints at that size on a sheet, even if that label appears on the sheet in a view with a 1/8" = 1'0" scale or a view with a 1/4'' = 1'0'' scale.
  • You can also control the visibility of generic annotations in the project separately from the host model family. See Managing Family Visibility and Detail Level.
Please select the Accept as Solution button if my post solves your issue or answers your question. Kudos welcome!
