How to add doors and windows to organic curtain wall?
Message 1 of 18
Could someone help me?
I want to add windows and doors to curtain wall that is made by face from conceptual mass as shown in figure
Replies (17)
Message 2 of 18
You need to remove some grids and mullions from where door goes and then replace the panel with a CW Door (or a Basic Wall to host a conventional Door).
Message 3 of 18
I tried that but I didn't have the aim
The curtain panel in this case can't be converted to basic wall, too. It can be converted to empty only.
Message 4 of 18
SteveKStafford
A door can't just go in a wall like that, it has to be designed so it can break into it. It's not going to swing up/down like the panels are facing in reality. As such the host form should have a void to carve out where your entry assembly would go. Then the curtain system will go around it. Then you model what the entry door system would be.
Steve Stafford
Message 5 of 18
This is a complex way. for windows what should I do!
Message 6 of 18
Do you have a CW Door loaded in the Project.  It should be in the drop-down. But, I isn't going to work if you are intending to put it on that sloped surface you're showing in your picture.   Be kind of a weird door opening.; don't you think. Maybe build a entry vestibule onto the structure for your door.
Message 7 of 18
Yes, I loaded this door.  I accept with you.. maybe I can't add doors or windows to this sloped wall. maybe I should build it.
Message 8 of 18
What kind of windows are you envisioning?  I mean the Glazing is there already. Are you thinking maybe a different shaped mullion?
Message 9 of 18
Create the "door" and "window" as adaptive families, then place them on nodes. Ever think about how they would work in real life?
Another way (not verified) is create them as face based families with void and host them on the curtain panels.
Message 10 of 18
Right glazing is there already. but I need to change the panel to curtain wall awning as picture  because this model  will be loaded to environmental programs to be analyzed. awning can entry fresh air to the space.aw.png
Message 11 of 18
I think many of these are  applied in real life. I accept with you that the door is hosted on void in a family but how to make it?
Message 12 of 18
Are you planning to make the doors plumb or tilted? Swinging, sliding?
Message 13 of 18
SteveKStafford
A void will cut out where the entry should go. What the entry should look like is design. Build it with walls, roof, doors or create a custom in-place family if regular forms aren't what you have in mind.
Keep in mind that for most analysis tools they don't care what your actual model is made up of, just what you tell the software it is made of, how big it is, where it is etc. The form alone itself is enough for broad analysis results.
Steve Stafford
Message 14 of 18
Automatic sliding?  I like it!
Message 15 of 18
Works this way too.
Message 16 of 18
I tried that. I could make voids. But I don't know how to build family  in place of void.
look the first picture.. I can cut the wall but I don't know how to add tilted glass in these places. Also, I have a vertical curtain wall but  the curtain grids are curved and the curtain panel can't be converted to door look the second picture.
Message 17 of 18
plumb and sliding and another tilted and sliding.
Message 18 of 18
I want exactly this door. How to make it?
