How to add coupling to pipe?
mpeperkamp
Hi @Anonymous,
Welcome to the Autodesk forum.
In the routing preferences of the pipe you have given the correct information.
When you select the pipe and go to edit type, you can select the routing preferences.
There by "transition" you have to select a family that makes a transition for you.
If there any question let me now.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
Thank you @mpeperkamp!
mpeperkamp
Hi @Anonymous,
Do you have a Transition?
Is your problem solved?
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
mpeperkamp
Hi @Anonymous,
If my post was useful to you, would you be so kind and accept is as a solution.
Others can see That and Find That information better.
Best regards,
Michiel Peperkamp
Cadac Group AEC
Cadac Group
Platinum Partner
