Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
How lock ".dat" file in workshared file - ProjectWise Cloud
BigPicture045
BigPicture045
I have a workshared file that is hosted on bentley systems cloud.
Every time I select elements such as text, lines, etc. it requires the file to lock permissions. This severely impairs workflow.
"Auto" element borrowing with button click or modifying element; the files are automatically checked out and checked in"
ProjectWise - Actions that Automatically Lock and Check Out Files in ProjectWise Integrated Autodesk...
Is there any way to check out or keep permissions? Currently the workflow is someting like this:
Loop:
select a text or line, it takes around 5-10 seconds to lock the file, make edits, 5-10 seconds to unlock file
Simply modifying a couple detail lines or text takes minutes instead of seconds.
Thoughts?
SteveKStafford
The last I looked Revit worksharing is not supported by ProjectWise. It supports posting and manage the presence of the file in their system but not multi-user concurrent access and syncing. You should refer to Bentley's current documentation for Revit integration with ProjectWise.
Since it's been a long while since I've looked closely...a quick search yields this via the Google AI response:
"No, Revit worksharing does not directly function within Bentley ProjectWise; while you can access and manage Revit files through ProjectWise, the actual worksharing functionality (dividing work into worksets and managing changes collaboratively) happens within Revit itself, and ProjectWise acts as a central repository for file management and access, not as a native worksharing platform for Revit.
Key points to remember:
  • Revit worksharing is managed by Revit server: To utilize worksharing in Revit, you need to set up a Revit server, which is not part of ProjectWise.
  • ProjectWise as a file manager: You can store and access your Revit files within ProjectWise, but the collaborative design aspects (worksharing) are handled within Revit.
  • Limited integration: While there are integrations to link Revit models from ProjectWise, this does not mean ProjectWise is actively managing the worksharing process.
Steve Stafford
