How I would add a project base point and survey point to my site plan view?
Message 1 of 12
How I would add a project base point and survey point to my site plan view? I've deleted my site plan view accidently and tried to create a new one but no base point shows on it
Replies (11)
Message 2 of 12
VV > Site > click on the + and tick Project Base point and Survey point boxes.
Message 3 of 12
I  accidentally deleted the site plan and I created new floor plan from view templates and renamed it site plan. I don't see any + and tick for project base point
Message 4 of 12
Did you type VV to open the table?
Message 5 of 12
I pressed w and nothing happened but however I got back the project base point. But the elevation markers are hidden and I am not able to unhide them . Is it because I have Revit LT?
Message 6 of 12
The visibility graphics are all greyed out and I cant edit them
Message 7 of 12
Back out and change the view template of the View's properties to Site Plan (this template may turn on Project Base point and Survey Point already so you don;t need to do anything further), or None if you can't find Site Plan then do the VV above.
Message 8 of 12
not W, VV or VG
Message 9 of 12
s.borello
VV or VG... visibility graphics.
Message 10 of 12
Might be easier to just press Reveal Hidden Elements (light-bulb on View Control Bar), select the PBP and SP (shown red) and press Unhide Category on the Contextual Tab.
Message 11 of 12
Why I cant place a topography surface on a site plan that I've create it? I've create a site plan but now I'm not able to create a topography surface when trying place it's points.
Message 12 of 12
This is unrelated to the Visibility State of the Survey Point and Project Base Point, if that is what you are thinking.  Did you find a solution to your origin question: "How I would add a project base point and survey point to my site plan view"? Let's stick with one topic per thread.
