how i can change group of room names in the same time that i did make with m room tag in revit
saliiimddd
Observer Observer
saliiimddd
Observer
Observer
mhiserZFHXS
What do you mean? Do you want them to all be the same? Or are the names all different? And at the same time you make the room tag? Like the instant you place the tag the name changes?
saliiimddd
Observer
Observer
all the same ,, like a mass changing after i did already put them
Select all the rooms and enter the new name in properties. Or create a room schedule, untick Itemize every Instance and enter the new name once for every room.
abposlovni
There's no native multi-edit for room names. The usual workaround is a room schedule with 'Itemize every instance' switched off — which only helps when the new name is identical for all of them.
We actually built a plugin for the general case: Automatic Room Naming and Scheduling renames and re-tags rooms in bulk from one dialog.
I'm the developer, so treat this as disclosure — you can try it for free at archplug.com.
