How does the Energy Analysis Tool calculate EUI?
mray422
Observer Observer
mray422
Observer
Observer
The energy analysis tool outputs Total EUI, but does not clarify if this is based on Site Energy or Source Energy. I would like to compare these numbers to the Energy Star Portfolio, but there is a big difference between Site and Source Energy.
Whilst this is a Revit plugin, you would be better off submitting this in the Insight 360 forum. The autodesk insight team often respond and will be able to answer this.
example this thread may help: http://forums.autodesk.com/t5/insight-360-energy-forum/insight-360-assumptions/td-p/6473908
A quick search of the Insight 360 forum also pulled up this thread.. http://forums.autodesk.com/t5/insight-360-energy-forum/calculating-the-energy-consumption/m-p/620143...
There are links to how whole building energy simulation works & Green building studio.
mray422
Observer
Observer
Thanks, I found exactly what I needed!
