How does one rename the SHEETS section on the project browser?
David125
David125
We have model that came from client with SHEETS section renamed on project browser. The sample in the attached file is from a genereic model.
Sheets cannot be renamed....but the information in the ( ) is the organization settings which will change when you select a different organization value.
The only other way it could be something else is if their Revit is setup for a different language.
If below is what you are talking about it's a two step process:
First, add a project parameter to the project either directly or through a shared parameter assigned to a SHEETS (one can also use OOTB parameters too). We called it "Sheet Disicipline" internally.
Secondly, one will want to set up the project browser to use the parameter through the browser organization. This can be configured through right-clicking on the Sheets>Browser Oragnization.
David125
Got it, thanks.
