How does one reference a plan callout in a section cut?
kgetev0711
kgetev0711
Thank You
loboarch
I am not totally sure what it is you are trying to do?
A plan callout can't be directly referenced when in a section view. You can add a View Reference to the section view that links to a floor plan callout, but that may need to be manually paried with some kind of graphic element to make it look the way you want.
If you explain further, I may have a better idea of what you could do.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
