How do you print a hyperlinked URL to PDF from Revit?
curtisridenour
Advisor Advisor
curtisridenour
How would you print a hyperlink with a URL to a PDF from Revit?
I want to be able to click on a hyperlink in a PDF that would take me to a location on a local server or on the internet.
@RDAOU
djforemandesign
You should be able to create a Shared Family or Project parameter that is a type URL. Then fill in the desired URL in each family and create a custom tag using that parameter.
Doing a quick test of a Shared Project parameter of a type URL and printing a PDF I was able to click on the link in the tag.
curtisridenour
@djforemandesign  I tried this the other day and nothing seemed to work. Probably user error. Thank you.
curtisridenour
I figured out my user error. In BlueBeam, you need to have the hand selected instead of the pointer to click on the hyperlinks.
djforemandesign
Glad you were able to get it to work.
mahan_motamedi-1991
Is it possible to have the same functionality for the conventional pdf readers ?
curtisridenour
What would you consider a conventional PDF reader?
