How do you change the Line thickness of Property Types without Override Graphics
djn9SY84
djn9SY84
Hey Guys,
how do you change the line thickness of materials?
I want to be able to model elements and adjust the thickness in the property types. I can change the surface and cut patterns by going into the material editor, but i cant change the line thickness.
I am modeling steel structures. what i want to be able to do is have main steel with a 4 thickness, secondary with a 3 thickness and additional with a 1 thickness.
i want to be able to cut my sections and have all my line thickness done. at the moment i have to go through each one and change each elements using override graphics in view.
Thanks.
syman2000
If you using families, you can set your family object into their own subcategories. Set the lineweight in the family editor and it should add those lineweight into your project automatically.
If you want to change the wall, floor, ceiling and roof assembly lineweight; you would go to visibility and graphics and change the cut line styles
If nothing works, linework tool is your best option.
djn9SY84
thanks for your reply.
I was able to change it by adjusting in the Familie editor by opening Visibility Graphics and then Object Styles.
