- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I'm trying to make simplest truss you can imagine and it's giving me nothing but problems. A: Is there a way to just designate a slope (pitch) to the trusses instead of a height? That would solve my problem. B: For reasons that I don't understand the truss won't (errors) attach to the underside of the simple roof I've created. C: When I enter the height of the truss, which is the bearing plate to the underside of the roof deck... the top of the truss is correct, but the top chord comes just slightly up through the roof deck at the base (see attached image and properties). If I raise the roof deck, then I have to raise the truss height value and the problem perpetuates. The only way I could get it to work was by dragging with width of the truss to the inside of the walls, which obviously isn't correct. How the heck do you work this thing?
