How do I Turn On/Off rcp Scan Locations in Revit?
jshubin
jshubin
How do I turn on/off Scan Locations in my Inserted .rcp point cloud file?
I'm sure I could import multiple rcp files, but that would be a huge hassle and harder to manage.
Can someone help? I can't seem to figure this out.
Thanks.
thamizhz
Please attach ur sample rcp file.
jshubin
Thank you but I don't see what attaching an rcp file has to do with my question at all. This is not a RECAP question about turning on/off scans in RECAP, but rather a REVIT question of turning then on/off while working INSIDE REVIT. AutoCAD and Plant3D both have this ability. I'm assuming REVIT must have it too, but I can't seem to find it.
For Revit 2017 - not sure about earlier versions.
Type" VG" and press return
Pick on the "Points cloud" Tab far top right.
untick the scan that you wish to hide in the current view. Pick the "OK" button
If you want to stop dis[playing in the Project for ALL views you can unload it.
To do this pick on the "Manage" tab
then pick "Manage Links"
then pick the "Point clouds" Tab
select the scan you want to unload and pick the "Unload" button bottom row of buttons.
jshubin
Thank you perri. 2017 has this option now. Earlier versions did not.
Hi jshubin
No worries - just came across the query and thought it may help someone.
Perri Launders
A:
E: perri.launders@nmcnomenca.co.uk
T:
M:
[image: FacebookLogo]
[image:
TwitterLogo] [image: LinkedInLogo]
PEOPLE INSPIRE EXCELLENCE
This email and any files transmitted with it are confidential and intended
solely for the use of the individual or entity to whom they are addressed.
Please note that North Midland Construction PLC is able to, and reserves
the right to, monitor e-mail communications passing through its network.
If you received this email in error please notify our IT manager at
richard.boot@northmid.co.uk. NOTE: that this is NOT the address of the
person who sent this mail to you but a general administrative address. If
you wish to reply to the sender of this message, use the "Reply" function
built into your email software.
Want to learn more about North Midland Construction? Visit our website:
www.northmid.co.uk
