Message 1 of 15
03:48 PM
- Mute
- Permalink
- Report
There are several threads similar to my question here, however, after reading those threads, I am still not able to get it working.
I have a family composed of a combination of multiple Solid/Void Blend/Extrusion. When the family instance is created in a project, I was only able to rotate around axis Z. When I tried to rotate around axis y and x, revit failed with the error message that "Revit can't rotate element into this position".
Can someone tell me what is the rule governing the rotation here, i.e., how to tell a rotation is valid or not, and how to get the rotation around any direction working?
Thank you very much!
