How do I place spot coordinates in a schedule?
LPRevit
LPRevit
Who knows how I can make a spot coordinates visible in a schedule?
I often work with the Dutch RD coordinate system.
It would be useful to be able to make a list of all coordinates.
As an attachment I have added a revit file with 4 coordinates.
Who can help me to get these coordinates in a schedule?
Revit designer
constantin.stroescu
I can show  my method to solve a problem like this.
I used for this a Generic Model Adaptive Family  and all was related to my country's official survey standard.
Have a look on the following screencast:
https://knowledge.autodesk.com/support/revit/learn-explore/caas/screencast/Main/Details/5c234926-2ef...
Constantin Stroescu
RDAOU
@LPRevit
If you want to stay away from dynamo, then @constantin.stroescu method would be the ideal way to do it.
If you are a coding enthusiast and dynamo is an option, I would suggest that you do it using dynamo
LPRevit
Thank you for this answer.
In my models the Autocad underlay is always rotated.
With acquire coordinates I adopt the coordinate system in Revit.
I have to turn the family in your example to get it to work.
I can see the angle to rotate in the project base point.
Revit designer
noelia.fernandez969Y6
Observer
Observer
Could you please upload a Dynamo screen shot so I can use this solution?
yasam_akinZ3NLC
Community Visitor
Community Visitor
could you share your dynamo script as a guide?
