How do I join the corner of these two curtain wall sections that were cut out of exterior wall?
daniel.kormos01
daniel.kormos01
Hello, if you look at the photo you can see what I mean. The curtain wall was placed inside of the exterior wall and then cut out of the wall using the cut geometry tool. I would like the corners of the curtain wall sections to join seamlessly.
Thank you!
Fillet the two curtain walls. Then use a void or opening to clean the corner of the brick walls.
daniel.kormos01
What do you mean by Fillet?
Fillet tool on Modify ribbon.
