How do I import an autocad file to create Toposolids topography?
JKspace424
JKspace424
I keep getting the following message:
The work plane of this view cannot be used for this operation.
This operation should be performed in another view or the work plane of this view should be set to a Level by using the Work Plane command.
I have no clue what to do with this.  I keep looking on youtube to find a better tutorial but still have no clue.
ABR_Kate
Hi again @JKspace424 ,
Just a quick follow-up: based on your error message and your mention of importing, it’s likely the issue is related to how the CAD file is inserted — and the units or work plane may not be matching your project setup in Revit.
I actually made a tutorial about this exact topic, which might help you visually walk through the process:
🎬 Revit Tutorial – Import CAD for Toposolid Topography (YouTube)
Here are some key points to double-check:
  • Make sure your CAD file uses real elevation values (Z-coordinates) for the contour lines.
  • When you import the DWG/DXF, double-check the units (Revit may misread them — metric vs imperial).
  • Use a Plan view (e.g., Site or Level 1) and set a proper Work Plane before creating a Toposolid.
  • Then go to Massing & Site - Toposolid - Create from Import and select the correct layer.
Let me know if the video helps, or feel free to share a screenshot of your import settings — happy to help!
Best,
Kateryna
KF | Archi BIM
