How do I get this cut line to appear in the top layer?
ct_studio
ct_studio
This is just a generic model next to a mass (left) cut in section. Does it have something to do with phase?
I don't understand the point, but if you make them both the same material and join them (via Join Geometry), the coincident line between them  should be removed - assuming they both exist in the current View Phase and View Phase Filter is set to Show Complete.
There's also a tool on the Modify tab called Linework (LW). Maybe just use the LW tool to make the coincident lines Invisible in the View?  Just a thought. A pretty good one, as I've been told in the past.  😉
ct_studio
It seems that no lines for the generic model category are visible in either cut or projection. That would probably address my issue.
Huh? You say "no lines for the generic model category are visible in either cut or projection". What do you mean and how does this relate to your question:  "How do I get this cut line to appear in the top layer?"
