how do i create an analytical model from an in place model
chhuanmawia18
Message 1 of 8
chhuanmawia18
i created stairs using the create in place models, how do i get the analytical lines of these in place models if i want to analyse them in robot or other analysis softwares
Accepted solutions (4)
Replies (7)
Message 2 of 8
RDAOU
@chhuanmawia18
You can get the analytical lines out of Stairs those are considered Architectural elements I believe ... For In-place, I am not sure if switching it to a floor or structural category would work...you can try.
What would work for sure is if you model the stairs as Sloped structural floors, then for sure you will have the analytical lines
Edit: you can check @dzanta 's screencast here but not sure how accurate that will export to Robot
https://forums.autodesk.com/t5/revit-architecture-forum/analytical-model-of-a-model-in-place/td-p/63...
Message 3 of 8
Alfredo_Medina
Select the Model in-place stairs. Click on Edit In-place. Then from Category and Parameters change the category to Structural Framing. Now do: Create > Model Line > subcategory: Analytical Model (projection), (if necessary select a new work plane) and draw the line(s).
Message 4 of 8
chhuanmawia18
thank you very much
Message 5 of 8
chhuanmawia18
thank you...but not sure where if i did the change parameter wrong or something.not able to get the stair element to show  up in the exported  file in etab file
Message 6 of 8
Alfredo_Medina
In the method that I suggested above, you draw the analytical lines that you need, because the model in-place does not produce them by itself. Then you should be able to export the model from a view that is showing analytical lines.
Message 7 of 8
chhuanmawia18
thanks so much for the reply ...i have another doubt , will this analytical model support dead load calculations in the analysis software since the material is not taken into the model.
Message 8 of 8
Alfredo_Medina
In Revit, you can use Analyze > Loads > Place loads, to add loads to your analytical lines. Then export. Or you can apply the loads in Robot.
