How do I create a domestic set of stairs with tapered treads?
stuart_willows
stuart_willows
How do I create a domestic set of stairs with tapered treads. i.e tapered treads instead of a mid landing.
Convert the Run to Sketch and draw the tapped steps.
stuart_willows
Thanks for that. Can that be done in Revit LT? I'm at home at the moment so can't check.
Viveka_CD
Hi @stuart_willows
I just wanted to follow up here, any progress on this issue?
Please mark any posts that help with "Accept as Solution" and thanks!
stuart_willows
@ToanDN wrote:
Yes.
https://knowledge.autodesk.com/support/revit-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/Revi...
Thanks but the video doesn't how to put tapered treads in!!
Use winder stair or convert runs to sketch and draw the treads.
