How do I connect columns to a pitched beam?
2013-09-06 11_28_50-Autodesk Revit LT 2013 - [Section_ Section 3 - 1331.rvt].png
The beam is continuous.  The connection details are not important.  They're some kind of plate welded to the beam and bolted through the column web. I don't need it to be able to do structural calculations.
Join won't select a structural column or beam.
Align creates a rotation error because of the beam's pitch.
The column height apprears to only change by the Level, but again the beam is pitched.
Setting the height above the beam breaks the beam.
awes
Select column, choose attach.
GHASEM_ARIYANI
hi
with Slanted Column You can connect them each other.
Of course If the column should be Slanted .
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
