How Did I Do This?
How Did I Do This?
PhilvK
Advisor Advisor
Message 1 of 18
How Did I Do This?
PhilvK
I somehow edited the extension on the handrail shown in the images below by extending the end in both the ‘elevation’ and ‘plan’ planes. I can’t seem however to duplicate this on other handrails, being able to only extend the handrail in the ‘elevation’ plane. Can anyone take a guess on how I accomplished this in both planes? I can’t remember, or figure it out. The file is attached if you’ve got time to look at it.  Thank  you!
Replies (17)
Message 2 of 18
PijPiwo
I'm not exactly sure what you're asking for, but is this (see my post) going to be any help?
Message 3 of 18
Sahay_R
Aaahhh, the mysteries of the universe! Let's see if it can be solved.....
Here is what I think that you did -
1) Tab to select the railing
2) Edit Rail
3) Edit Path
4) Additional Sketch lines that looked like the bold lines.
5) Accept by clicking the green check mark
Rina Sahay
Autodesk Expert Elite
Revit Architecture Certified Professional
Message 4 of 18
PhilvK
The problem I am having is that when I try to draw a line perpendicular to the rail, I get the little circle with a line in it, and the message that says I ‘can't draw because work plane is at a very sharp angle in this view’, and I can’t seem to switch the work plane. When I do switch the plan to a plan view, it goes back to a named reference plan when I go into rail editing mode.
Message 5 of 18
PijPiwo
You can do it by adding an extension (see pic), so when you go to Edit Rail -> Edit Path, that horizontal piece is available.
Message 6 of 18
I am not in front of the computer but if I remember correctly, the horizontal extension segment cannot be modified, e.g. shorten or lengthen. The length is set in the extension type or something like that.
Message 7 of 18
PijPiwo
'the horizontal extension segment cannot be modified, e.g. shorten or lengthen.'
Yes, it can.
Message 8 of 18
Just checked and yes it can.
Message 9 of 18
PhilvK
No matter what I do, I can't draw a horizontal in the plan plane, only in the elevation plane of the handrail!!
Message 10 of 18
Sahay_R
Correction - forget the blather about working in a section view - draw in a 3D view. The stuff below the original rail is what I was messing around with.
Rina Sahay
Message 11 of 18
PhilvK
I can draw easily in section / elevation view, but not plan view.
Message 12 of 18
PhilvK
ToanDN - How did you draw this segment? I assume it is the horizontal plane of the landing. That's the type of segment I did before but can't get back to being able to!
Message 13 of 18
I had to create a new handrail type and turned on the top extension, which is what @PijPiwo mentioned.  But it is not the same with what you did because you were able to add it under the handrail type without extension.
Message 14 of 18
PijPiwo
'But it is not the same with what you did because you were able to add it under the handrail type without extension.'
@ToanDN imho, this is impossible. How do you know it was done w/o adding an extension?
@PhilvK, do you remember drawing this segment or you’re not sure (do not remember) how it got there?
Message 15 of 18
@PijPiwo  if you look at his file, the handrail type does not have any extensions.  Can it be overridden somewhere?
Okay.  Here is how I think he did:  Added an extension to handrail type, stretched the horizontal segment, remove the extension from the handrail type.  The segment stayed.
Message 16 of 18
PijPiwo
@ToanDN, if the extension was modified in any way with the edit path tool, it will remain in place even though it’s removed from the handrail properties. The only way to remove it is to manually delete blue line segments.
Message 17 of 18
I edited my post while you were posting the above. You are correct.
Message 18 of 18
PhilvK
Yes! That is what I did (see the accepted solutions). Thanks to all 3 of you for taking time out to look at this!!
