How can resolve union of floors
arqyt
arqyt
How can we resolve the union of floor layers?
regards
Is it right? How can I resolve this?
Jose M Carralero.
ArqyT
constantin.stroescu
I suggest  ,beside joining floor, to intercalate a short wall ( as you will do anyway if the floors will be at a biger distance) of the same material as the floor core:
  1. join the two floors
  2. make a wall of the same material as the core of the floors
  3. in a section view, align the wall as necessary - Image 01
  4. in section view , join the wall with the floor - Image 02
  5. in section view stretch the wall so  to be entirely into the floors - Image 03
If you have a more complicated section , you can use,also, but only for 2d , the Cut Profile from View..
Image 01
Image 02
Image 03
Constantin Stroescu
arqyt
Yes, it is an ingenious solution.
In this line, i try introduce a structural beam, which may be more consistent.
I tried the 2 options and both solves half the problem. Look the image.
I do not understand the whole algebra of resolution structure of priority layers of walls / floors.
Try it with aline walls, dont work with a logical solution
Thank you teacher for help.
Jose M Carralero.
ArqyT
constantin.stroescu
I made a screen recording of what I've described in my previous post...
https://chronicle.autodesk.com/main/details/96e7e330-bfd1-47e8-b950-8c92ab0b214d
Constantin Stroescu
arqyt
Of course your idea gives a better response.
I greatly appreciate your effort.
Thank you very much
Jose M Carralero.
ArqyT
