How can I transfer text and lines from a group to a generic annotation family
StephMarsh
Message 1 of 15
StephMarsh
I have a lot of groups in my template files.
But I need to now make them families. I have a chart that would be for New York State or New York City.
It would work best as a family. I don't want to remake the chart.
Any ideas?
Accepted solutions (3)
Replies (14)
Message 2 of 15
What about Grouping Content and Saving Group to RFA?
Message 3 of 15
syman2000
Normally I would place it in drafting views and save it as group file. That way you can copy and paste the drafting view into next project easily without much hassle.
If you want to make it as family, I would use the titleblock route. Generic annotation family will scale your object/text. It is messy. Detail family will show your lines but not your text. Titleblock is a middle ground where it will display your text and maintain your lines. When you load in to the project, it will only appear on sheet view.
Message 4 of 15
StephMarsh
I don't see where I can save the group as an .rfa file
Message 5 of 15
StephMarsh
Can I use the text and lines I already draw?
It isn't letting me copy/paste them into the title block family.
Message 6 of 15
Find the Group in the Project Browser, right-click on it and press Save Group.
Message 7 of 15
StephMarsh
When I save the group I only have the option to save it as a .rvt file.
I am using 2020.
Message 8 of 15
Ah! I misunderstood. I see now that you want to pull stuff out of the Project and put them into a Family.  You know, FWIW, you can load Saved Groups it other Projects (Insert Tab=>Load as Group).
Message 9 of 15
syman2000
This is the pitfall of Revit. Whatever you create in project environment cannot copy over to family easily. I can't even transfer object(s) from views to sheets. Only way I've seen done is export to DWG and then insert the DWG into the family. It is something Autodesk need to fix. Right now you can save group and then load them in.
Message 10 of 15
StephMarsh
That is what I am doing..
THanks
Message 11 of 15
StephMarsh
Yes. I know that. I wish Autodesk would make it easier.
And I with we could phase rooms!!!!
Message 12 of 15
lucdoucet_msdl
Errata: Obviously, other replies mentionned the same solution while I was composing this response. Although, curious to note that @barthbradley'.s solution is to avoid the stated problem! 😉
@StephMarsh
I'm assuming from your title and use of the word "chart", that the "groups" are Revit detail groups and are in the form of a grid of lines and text.
If so, for each detail group, you could:
1. Place them on an empty view at the scale required (I will assume 1:1);
2. Export to DWG the view;
3. Create a new generic annotation family and set scale to 1:1;
4. Import CAD and explode the import;
5. Select all lines and assign them to the line object style required. Do the same to the all the text elements.
6. Purge the unused layers in the generic annotation.
You could also export all your detail groups on one mega DWG to RFA to process steps 5 & 6 at the same time, then create the individual RFA files from that work file and erase the data not applicable in each seperate chart RFA.
-luc
Message 13 of 15
..."avoids the stated problem"? Are we reading the same thread? 🤔
Message 14 of 15
lucdoucet_msdl
@barthbradley
My bad, I mis-read!
Your post was tagged as "a solution" by the OP with your FWIW comment. Need more coffee :-).
-luc
Message 15 of 15
jonsCTL39
I know this is an old thread, but none of the "solutions" offered what was asked for.
Create a new Detail Item family.  Then, in a project, edit a detail group to select the individual elements you want to be in the family.   Copy & paste them into the family.   Load into the project. Done.
