How can I show unjoined wall lines between structural and non-structural walls in plan and section views, while keeping the elevations visually seamless without joint lines?
19104028
Observer Observer
19104028
Observer
Observer
BEFORE JOINING WALLSBEFORE JOINING WALLSBEFORE JOINING WALLSBEFORE JOINING WALLSAFTER JOINING WALLSAFTER JOINING WALLSAFTER JOINING WALLSAFTER JOINING WALLS
CGBenner
@19104028
Hello, and welcome to the Community.  Is this done with Revit?  If so I can move the post there to get you the most help with your question.  Thank you!
Chris Benner
Observer
Observer
Yes, it is done with Revit.
RDAOU
@19104028
You need to provide more info on the Wall types you are using, their Layered stracture built up and the material you are using. There are different scenarios and countless solutions for each. example, use a walls of multiple layers (cores of different material for structural vs nonstructural and finish layers of the same material); the structural material of the cores will not join and keep the common edge in plan view while the finish layer of the same material would join seamlessly in elevations.
In order to make the life of those trying to help you easier, it would be good if you attach the sample file where one may check which approach suits best as a solution for the issue you are having rather then us trying to recreate it
