How can i resize the height of the row in schedule and quantities?
randiegarcia
Message 1 of 9
randiegarcia
a blessed day to all!
i have a question the size of the height of the row on schedule/ quantities are too small for me and i want to resize it, not in the sheet mode but in the schedule and quantities mode, herewith is the attached file for your reference. thank you.
Replies (8)
Message 2 of 9
High-res screen?
Reduce the Windows Display Scaling to 100% and see how it looks.  If okay, gradually increase the % until the rows start crunching again then stop and knock it off a notch.  Never exceed 150%.
Message 3 of 9
randiegarcia
still the same sir, i try to adjust my resolution, how can i change the height because its uncomfortable to see the small text and height row , in that view. i can change the column width but the height row and text still the same and it become smaller. hope that you can help thanks for your effort.
Message 4 of 9
ennujozlagam
@randiegarcia hello, i think at the moment is not possible to change the height, the only thing you can do is to change the height of the text in the appearance (sheet list properties) thanks
Message 5 of 9
amorap
Hello from Spain
In revit 2018 when you are in a schedule table, there are an option in the ribbon to adjust the height of a row, but for any unknown reason it is grayed out and cant be used.
Hope that sombody can explain how to activate this option.
Regards.
Augusto Mora
Architect & teacher of Building Projects at CPIFP Pirámide. Huesca (Spain).
Revit 2014 certified profesional.
Message 6 of 9
randiegarcia
thank you sir, it is also available in revit 2017 but it is only applicable in the headers / title but on the row below which contains the description, cost and family it will not be applicable.
Message 7 of 9
randiegarcia
yes it is possible in sheet, i am asking because might be others know how to change the size. thanks a lot your help highly appreciated.
Message 8 of 9
ennujozlagam
@randiegarcia hello, this issue is still in Revit Ideas. you can check it HERE. thanks
Or click HERE. thanks
Message 9 of 9
kadmonkee
i assign three text styles for all my schedules
TITLE = 1/8" BOLD
HEADER = 1/8"
DATA = 3/32"
i agree it is sometimes difficult to see Row Heights in the actual view, but when placed on a sheet it works just fine.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
