- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Could someone help me remove the rows with red circles from my schedule table?
I have attached a screenshot.
@ToanDN Thanks, this worked! Can you guide me on how I could save a schedule from one instance to the desktop and then insert that schedule to another instance?
@ToanDN this would help if I have both the projects opened in one instance. Is there a way, I could copy the schedule table to the desktop and then insert it to a new project - mainly cause both the projects would be open in different instances.
No. You need to open both projects in the same Revit session in order to copy paste.
If not, then open the other project and Insert > Insert from File > Insert Views from File > then navigate to your original model and choose the schedule to insert.
