How can I recover a revit project file from a revit server?
robert.millerQXT47
robert.millerQXT47
We have our projects on a revit server. Not a shared drive. I need to recover a previous version of a revit file but I can't find out how to do it from a revit server location? The collaborate/ restore backup does not work for a revit server file location. Not any method that I have managed to discover yet anyway....
I can see the backup files and file size, time, etc on the Revit Server Administrator web page but I can't seem to find those files on the revit server or how to restore the file.
Please help.
eizinmyat
How about using the command-line lock utility to unlock the server for backups. I attached the link so that you could check. I hope it helps you.
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-CAB9FAB8-4F74-43F5-88D4-C0DCD78D242B
https://help.autodesk.com/view/RVT/2024/ENU/?guid=GUID-0D4EA474-A104-4CB2-910D-1B4F44A596FD
Ei Zin Myat
Technical Sales Unit Engineer
ONESTRUCTION Co., Ltd.
eizinmyat@onestruction.com
robert.millerQXT47
I am looking for something similar to the method of recovering backups using restore backup and then navigating to the backup folder and then picking the backup out of a list of backup versions where it was saved and either rolling it back or saving it somewhere. I attached a screenshot (1) of that method. Is there no way to do this with a revit server file? When I go to the revit server administrator webpage (FYI - I didn't set up the revit server, my company IT sets that up and has all of the permissions) I can see a list of backup versions and the file size but I see no way to obtain one of those backups. I have also attached a screenshot (2) of that page showing the backup versions. Can I get one of the revit server backup versions?
