第 1 条消息(共 5 条)
How can I plot to printer margins
In Autocad everytime you plotted you could pick Display, Extents, Layout, Window. Window was handy if you had items outside the sheet or the sheet wasn't centered on the page properly.
In Revit, I haven't found out how to do this. We have sheets set up, but occasionally there are items outside the sheet, like drafting views that can't be cropped, or legends too. Or just additional plans.
Under paper placement there is center or offset form corner, but I can't figure out how you pick the extents of the sheet (which are set to A1 size).
