How can I move multiples objects with Dimensions
jysnbnvdz
Message 1 of 11
jysnbnvdz
I know that if you want to move an object with more precision you can make a dimension, then click on the object and then enter the measure in the blue text's dimension, but if you choose more than one object you can't edit the blue text's dimension, how can I do to move multiples objects with dimensions?
Replies (10)
Message 2 of 11
Do you mean moving them al the same distance?  If so, place a dimension string to all elements and lock each dimension in the string, except for the one you want to adjust.
Message 3 of 11
Sounds like you may have a hidden constraint. Reveal Constraints and remove it.
Message 4 of 11
edwin.prakoso
You can modify the dimension value even when you select multiple objects.
Do you have any error messages?
Cheers,
Edwin Prakoso
Message 5 of 11
jysnbnvdz
thank you so much, but i want to move all the objects that i have selected
Message 6 of 11
jysnbnvdz
thank you so much, it seems the problems was a restricted dimension
Message 7 of 11
aperdueTGQS4
So I have been able to do this for quite some time but recently it's not letting me modify dimensions (permanent or temporary) when multiple objects are selected. Did I mess up a setting some where? I am using 2024.1.
Thank you,
Austin
Message 8 of 11
adambikesBVR58
revit 2025 here and it is not allowing me to do it as well
Message 9 of 11
adambikesBVR58
found the fix for move multiple objects with dimension when it is not working. You need to "Activate the dimensions".  See attached
Message 10 of 11
Phillip_HudsonEV2XB
Community Visitor
Community Visitor
Thank you. Good to know Activate Controls also changes how moving multiple objects with dimension lines is experienced.
Message 11 of 11
tobias_jordanVSHLS
Community Visitor
Community Visitor
Thank you!  This is the answer I was looking for.
