How can I make a sheet that contains a detail of every wall type in the project?
elisag23
elisag23
Hi, my boss has asked me to generate a sheet with a detail of each of the 7 types of wall there are in the project. Now, it's not a detail from the existing plans what I need, but to "model" (draw) a piece of each wall and list the composition as references (like on a map when you see the diferent kinds of colours and lines and what each one means)
How can I do this? Is there a way to model this pieces of wall in a different "space" in the project?
tmCL9N6
jay_colc
you can do this in a Legend with Legend components - Annotate Tab > Detail Panel > Component Drop down > Legend Component
The only issue here is that you have to manually label them.
I have seen several other ways, create them in the model (real object not Legend Components) use tags to label and then save as an image and drop into a Legend
or
Create them in as above in a View and set them to a Phase that is not used so never shown but this is a bit more complex
Jay Colcombe
Autodesk Certified Instructor
Is this what you are after?
elisag23
YES
Check out this recent discussion/thread:
Solved: Re: Wall schedule - Keeping materials in correct order - Autodesk Community - Revit Products
It describes a few approaches you could use.  I think it'll help you a lot.
