How can I join handrails at the landings of stairs?
Message 1 of 8
I am going a little insane and cannot seem to get these stair railings correct. I am attaching an image of what I am trying to do below.
Basically I am trying to join the handrail at the landings of the stairs. Seems like I can only edit the profile of the handrail. Is there a way to connect the two handrails?
PLEASE HELP!
Replies (7)
Message 2 of 8
Have you tried to model it as a single continuous handrail?
Message 3 of 8
No,
Right now I modeled two separate railings and just edited the path of the handrail. How can I model a continuous handrail that's attached to the rest of the railing (guardrail, balusters... etc.)?
Message 4 of 8
cbcarch
If the railing is Hosted to the Stairs (both runs), and the sketch line is drawn continuously, the railing should join automatically.
Try a quick test:
-Create a New Project.
-Draw a new Stair, using "Stair by Sketch" from Level 1 to Level 2.
-Make the stairs in (2) alternating runs--like your attached photo.
-The default Stair Type usually contains a hosted railing, which should automatically clean up in the center/"newel post" section as in your example.
-Then, compare the "test" stair with the one in your project, and troubleshoot it.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Message 5 of 8
I did that earlier, but the problem with that is that it joins the guardrail too. I only want the handrails to join, and the rest of the railing will stop at the last riser, like in the photo I attached.
Message 6 of 8
If you want to replicate the photo, then the guards are non continuous pieces and the handrail is a continuous one.  Model the guards and the handrail as separate railings.  Both can be hosted by the same stairs.
Message 7 of 8
Is that just a floating handrail? or did you use the wall mounted one? Sorry for the dumb question.
Also, how will this work at the floor landings. I have 12 floors to go up.
Message 8 of 8
See attached.  It probably doesn't solve everything but you get the approach.
