How can I find gravel hatch in revit
jorgedacunha60
jorgedacunha60
Where can I find gravel hatch, and loading in revit 2017?
Thanks in advance.
Just Google it. There's plenty of them on-line that you can download for free.  You're looking for a *.pat file specifically.  Those are what Revit uses to create a its Model and Drafting Patterns.
constantin.stroescu
try this site: CAD Hatch
http://www.cadhatch.com/free-downloads/4588167679
or you can load the  pyRevit application:
http://revitaddons.blogspot.com/2019/01/pyrevit-v4610-4611-upcoming-pyrevitlabs.html
Using pyRevit you will be able to customize your pattern very easy..
Constantin Stroescu
hugha
Try the attached familiar pattern, upscaled by 10 in HatchKit to directly load into Revit
hth,
Hugh Adamson.
www.hatchkit.com.au
Yien_Chao
you better import it from a .pat files from Autocad.
it commonly used.
