How can I edit the size of a label on an out of the box family
AidanHawkins
Message 1 of 12
AidanHawkins
Please see below,
I am trying to edit the size of the label on a pre existing family - Specialty_Equiptment_Refridgerator
How can this be done? i want to make it half the size
Replies (11)
Message 2 of 12
d.ahmed.LW
@AidanHawkins, as far as I understand from the image the Text Label has been loaded into another family. You will have to select the Label, click on edit family and then open the Type Properties. Here you can change the text size and everything else. Load it back into the family later.
Do let me know if I have misunderstood your question.
Message 3 of 12
AidanHawkins
Thanks but I cant edit family when i select the label
Can I share the family with you?
Please find attached
Message 4 of 12
d.ahmed.LW
Unfortunately my current device only has Revit 2021. I think your family is saved in a newer version. Could you send a screenshot of the toolbar when you select the label? Is there no edit family option?
Message 5 of 12
AidanHawkins
Message 6 of 12
d.ahmed.LW
How about deleting this and loading a new Generic Annotation as per your requirements?
Message 7 of 12
AidanHawkins
I deleted it and added a new generic annotation
But I dont know the steps how to create a label that I can change the name in in the project
Message 8 of 12
d.ahmed.LW
Okay here is the solution to that: Using a door family as an example:
@AidanHawkins
Message 9 of 12
d.ahmed.LW
If it helped do mark it as solution. Thanks!
Message 10 of 12
AidanHawkins
Im sorry but I cant find this video
Message 11 of 12
d.ahmed.LW
Uploading Again:
(view in My Videos)
Message 12 of 12
Associate the nested label parameter with a parameter of the host family.
