How can I edit or create a hatch/filled region?
適用対象外
3,505件の閲覧回数
9件の返信
メッセージ1/10
適用対象外
I am trying to do a 2x4 second look grid.  I want the regular 2x4 but with a grey line through the center so it looks like a 2x2 but it's obviously not.
How can I get a regular 24"x48" black line crosshatch with a grey line every other 24".
0 件のいいね
解決済み
3,506件の閲覧回数
9件の返信
返信 (9)
メッセージ2/10
All lines in a pattern will have the same color.  You need two patterns, one is black 2x4, another is gray line.  Place them together and line them up to get the look you are after.
0 件のいいね
メッセージ3/10
適用対象外
Well, that's easier than what I did last time, but as far as I can tell, you can't have two patterns as a material.  Which would be the best scenario.
0 件のいいね
メッセージ4/10
Well you can sort of have it.  If it is for a ceiling then you can Create Parts from the ceiling, change the material for Parts, and set the View to Show Both.
メッセージ5/10
適用対象外
Okay!  And how do you do that?
0 件のいいね
メッセージ6/10
解決済み
See below:
0 件のいいね
メッセージ7/10
適用対象外
Thank you very much!  How else do you use that?
0 件のいいね
メッセージ8/10
How else?  To show walls with both concrete cut pattern and solid poche, for example.
Or if you need to know about Parts then read about it here.
0 件のいいね
メッセージ9/10
適用対象外
Okay, so that worked EXCEPT, it doesn't print.
0 件のいいね
メッセージ10/10
Give the ceiling 1% transparency.
0 件のいいね
