How can I constrain a family to not be rotated from its desired position
AidanHawkins
Message 1 of 12
AidanHawkins
How can I make sure that a family is never rotated in the project, that it is able to move freely in the project but it is not able to change direction
Replies (11)
Message 2 of 12
Let's see this Family. Post it here.
...what about utilizing PINNING for this?
Message 3 of 12
AidanHawkins
Please see attached
Ive tried pinning it but it still rotates when I load it back into the project
Message 4 of 12
Is this the "person on desk" family again? Use a tag and tag the room or the desk or whatever instead.
Message 5 of 12
AidanHawkins
yes it is
Sorry could you please explain using the tag further? What will it do
Message 6 of 12
You're going have to explain that one to me. What do you mean " it still rotates when I load it back into the project"?
Message 7 of 12
AidanHawkins
Here is an example
The two types that have a tick on them are in the desired direction, meaning I never want to be able to rotate them, like the two others that are not in the desired direction.
After pining the object, I am still able to rotate the family to the undesired direction
I want to remove the capability of rotating the family
Message 8 of 12
curtisridenour
There is always dynamo. FamilyInstance.SetRotation node could probably be deployed to rotate all your instances in the project back to 0°.
Message 9 of 12
curtisridenour
@ToanDN is right though. you should use a nested annotation or tag it with the proper symbol.
Message 10 of 12
I can't rotate your family if it's pinned.
Message 11 of 12
mhiserZFHXS
I'm still confused as to why these are 3D elements instead of annotations... And what does it matter if they CAN be rotated? Just don't rotate them?
Message 12 of 12
yes it is
1. Pinning elements in the family does not prevent the family be rotated in the project.  You need to pin them in the project.
2. To use the tagging approach:
- create a room tag for each symbol
- tag room (if a room needs multiple symbols then tag them multiple times using different tags)
