how can I add up lengths in a schedule?
svalente9GJKH
svalente9GJKH
Trying to add up calculated length of studs in a schedule.
I see there is fx calculated tool but not sure what formula I would use?
I'd also like to divide this total by 16'
Any thoughts?
Thank you
Revit_Whisperer
Length / 1' 4" + 1  assuming there is only one stud at each end and no openings
svalente9GJKH
I dont want the stud count,   I want to add up all the lengths like 12'-6" + 10'-0"  etc...
Format tab > set the Field to Calculate Totals.
Revit_Whisperer
If you just want a total then uncheck itemize on sorting and grouping and on the Formatting tab select Length and Calculate Totals....
svalente9GJKH
this works,   know a good way to divide after totaling?
