Hosting a custom railing on staircase
How can one host a custom railing onto a stair which is not in our scope? Meaning, that the stair element will be modeled in Revit Structure and I have to link the Structure model and host my architectural railing to it. Is this possible? If it is, I require some info regarding how this is possible and how much can I customize the railing by following aforementioned procedure.
Copy/Monitor the stairs so you can host to it...or build the railing manually by inputing all the heights in the properties.
