Horizontal Section Cut in Revit 2018
Message 1 of 9
I can cut vertical sections on an elevation all day long.  But can't seem to sort out how to put a horizontal section cut tag on an elevation.  Revit version 2018
Replies (8)
Message 2 of 9
dferreira-blackwell
Horizontal section equals callout in the plan. You can put a horizontal section in a vertical view. go to any plan and create a callout. change View range as needed.
Or do you want section mark to appear horizontal while section itself is vertical?
Message 3 of 9
dahld
While using the Section view, change the ‘Section’ to ‘Detail’ (in the Properties palate).  You will then be able to cut a horizontal section.
Message 4 of 9
I guess I am stuck in old fashioned drafting conventions.  The callout technically would be an enlarged elevation view if placed on an elevation.
I am trying to cut a section through a vertical reveal on a wall elevation.  According to my firm's drafting conventions this would be a section cut mark, placed horizontally on the elevation.  I am not so concerned about the actual view created, as I can just draw the reveal in detail lines.  I just am having a hard time wrapping my around the impossibility of placing a horizontal section cut mark.  There has to be a way.  Doesn't there.
Message 5 of 9
Please see post #3. It provides a valid solution.
Message 6 of 9
PhilvK
I don't see where I can change the Section to Detail View. My properties panel is blank when I start a section cut ??
Message 7 of 9
PhilvK
Please disregard, I found it!
Message 8 of 9
richH5Z5C
Late to the party but perhaps this will be useful to someone at some point - You can draw a section vertically and then use the Align (AL) tool to force it horizontal by aligning it to any horizontal line in the view (just draw a Detail Line if needed and then delete it)
Message 9 of 9
josh
Observer
Observer
Draw a vertical section approximately where you want the horizontal section cut; then rotate the vertical section annotation 90 degrees.  It will now be a horizontal section looking up or down.
