horizontal alignment of text & color fill legend on sheet
Hi everyone
i am trying to place two partial plan views (color schemes with color fill legend) on one sheet but they do not fit without rotating. The problem is when I rotate them clock/counterclockwise, the color fill legend rotates along which looks awkward moreover the room tags also look silly when they rotate too
is there a way around this to keep text and legend straight
RDAOU
@Anonymous
You can rotate the Crop Region of the view ... this should rotate the view on sheet and keep tags and Fill Legend horizontal...some use duplicate views on sheet rotate one +/-90 on sheet and use the legend from the duplicate (horizontal) placed outside the sheet but I'm not sure if that preserves tags horizontal...will have to try it
