Good evening everyone,
is there a way to set a horizon line in the views?
Thanks for your help.
Solved by barthbradley. Go to Solution.
Solved by constantin.stroescu. Go to Solution.
use Place Background to see where ground finishes an sky begins..Draw a detail line where they meet... Set backround to None
Constantin Stroescu
for interior perspective place background on Wireframe view to see the meeting line
Constantin Stroescu
@f.annoscia1XRNMD: Are you aware that you can add a Background to any View via the View's Graphic Display Options? If you choose Background Gradient you'll have coloring options for Sky, Horizon and Ground.
FWIW.
Hi @constantin.stroescu. I would like to ask you how do you insert the trees separately in the sheet? In the image you posted there is the view inserted and apart from the trees, which however are also visible in the view. The imagine is very nice with trees.
Thanks if you want to answer me.
you have to make a database of trees (and people ) in .png or .tiff format with alpha mask ( transparent background).
Alpha mask is mandatory if you want to place them in foreground .....
These bitmaps will be placed and adjust while in Sheet..
https://www.youtube.com/watch?v=KLlIvh3LA2Y
Constantin Stroescu
