Hollow Metal Doors and Frames
gkwas
gkwas
All of the doors in my project are wood doors with drywall frames. When I create a door type legend all of the doors are shown with 4" heads. I need a standard 2" head. Is there anyway to accomplish this?
cbcarch
Yes.
-Create a new Door Type with a 2" head frame.
-Depending on how your Door Families are built, you may be able to use a dimension and parameter to control the door head thickness--either with an Instance or Type Parameter, which when loaded into the Project can be changed.
-However you do it, use the family w/ 2" head for the Legend View.
Cliff B. Collins
Registered Architect The Lamar Johnson Collaborative Architects-St. Louis, MO
Viveka_CD
