Highlight Which Levels / Grids are Copy Monitored
rony.ghadbanLAC
Message 1 of 24
rony.ghadbanLAC
Hi forum,
Is there a way inside a Revit view where I can highlight which levels/grids are copy-monitored and which are not?
Similar to view filters, or work-sharing displays.
Thanks in advance,
Rony
Replies (23)
Message 2 of 24
Message 3 of 24
Use a different level type for them then you can filter by type name.
Message 4 of 24
rony.ghadbanLAC
This Link tells me how to copy/monitor levels and grids.
I am asking how I can check which levels or girds are already copied / monitored and which are not in a view, a quality check view of already copied / monitored levels or grids.
Message 5 of 24
rony.ghadbanLAC
Seems my question was not clear enough.
I am saying:  I already copied / monitored all levels and grids in my model from another datum-linked model.
Sometimes users by mistake remove/stop copy / monitoring, so I run quality checks on the entire model, one of them is checking whether all levels and grids are still copy / monitored, how can I do this without clicking on each one of them to see the if they are? Can I use views with certain settings? filters? schedules...etc.?
Thanks in advance,
Message 6 of 24
jay_colc
This cannot be done directly in Revit and can only suggest a Dynamo Script to identify these elements
Jay Colcombe
Autodesk Certified Instructor
Message 7 of 24
rony.ghadbanLAC
I suspected this would be the answer 😞
How would the Dynamo definition be?
Thank you for your reply.
Message 8 of 24
You didn't go deep enough. I suggested a different workflow.
Help | Copy/Monitor Parameters for Levels | Autodesk
Help | Specify Options for Copy/Monitor | Autodesk
Help | Copy Levels for Monitoring | Autodesk
Help | Display a Linked Model in Halftone | Autodesk
Take a hard look at the last Link.  For now, that may be your quickest solution.  Halftone the Link.
Message 9 of 24
Alfredo_Medina
Monitored elements display a symbol next to the element being monitored. Is that not enough?
Message 10 of 24
You know, @rony.ghadbanLAC, it's all in the interpretation of what you mean.  My initial read was that you are unable to distinguish between Link Levels that are Monitored and Link Levels that at not Monitored IN A VIEW.  Now you've added that you want to include those "which are not in a view" for a "quality check".   What does this mean? What is it exactly that you are trying to facilitate.
Message 11 of 24
rony.ghadbanLAC
only when you click them, select them, I have tens of levels in my project, do I click them one by one in the view?
Message 12 of 24
rony.ghadbanLAC
my post is simple:
I have a model where all levels and grids are already copy-monitored from the linked datum file, I run daily checks in a plan view for girds and elevation view for levels to see if they are still copy/monitored my clicking them or selecting them to see the copy / monitor icon / symbol.
I am asking here if there is a way to setup this plan and elevation view to have some graphical settings/filters..etc. that highlights the levels and grids that are still copy monitored to differentiate from  the ones that are not, instead of me clicking them or selecting them to see the icon / symbol?
Thank you in advance,
Message 13 of 24
rony.ghadbanLAC
clicked: still copy / monitored:
clicked: not copy montiroed:
is there a workflow to highlight graphically in the view the ones that are copy / monitored from the ones that are not instead of clicking or selecting them?
Message 14 of 24
So, you want to check which Link levels are monitored AND which levels were, at one point in time, monitored in the Project. Well, I don't know how you could tell what Link Levels were once monitored. They are either monitored or are not monitored. But you can see what Linked Levels are still being monitored in a Project View (which shows every Level in the Project) by selecting all Levels looking for the Monitor Symbols above the Levels - as @Alfredo_Medina mentioned.  Or you could just use the Copy/Monitor tool and Monitor Link Levels. Revit will let you know if a Level is currently being monitored.  Obviously, if someone did accidently press Stop Monitoring - which I assume is what you're trying to determine - then you would have to run Copy/Monitor to correct it anyways.  So maybe the "daily check" starts with Copy/Monitor.
Message 15 of 24
RSomppi
Have you looked at "Coordination Review" as an alternative to graphical representation.
Message 16 of 24
rony.ghadbanLAC
Thank you all for your reply, still your answers are not about the very simple poitn I am asking:
I have everything set, all copy monitored, all levels shown, I run coordination review to check for changes in levels and grids but it does not tell me if a level was stopped monitoring or not.
I just want to know if there is a simple setting in the elevation view that highlights which levels are still copy / monitored and which levels are not, just a by view, just by looking at them when i open the view without having to click them and look for the icons. (e.g. the copy / monitored levels appear in green color, the not copy monitored in red...).
If there is no way of doing so then I can accept that and carry on with my regular checks.
thanks,
Message 17 of 24
Alfredo_Medina
Apart from what has been mentioned above (symbols), there is no way to do what you want, unfortunately. Not even in Dynamo, I searched for something that could detect monitored elements and I did not find anything.
Message 18 of 24
RSomppi
thanks,
Message #6 tells you it is not possible but you continuied your quest. Thus the continued responces.
Message 19 of 24
rony.ghadbanLAC
Thank your for your response.
Message 20 of 24
rony.ghadbanLAC
it said also "....can only suggest a Dynamo Script to identify these elements". Then at the end I got a reply: not even in Dyanmo can be done.
You do not need to read my posts if you are really bothered with the extra messages after message #6
I am here to learn and for knowledge sharing, not to hear about your nagging about reading additional messages...
