Highlight Items in a selected level
Is there a way to select a level and all the members on the level are highlighted? I have imported a model with 100+ levels, and would like to delete the levels with no members associated.
If I delete a level, members on that level are deleted and I cannot tell which ones. Thanks!
Sean_Page
When  you select the level to delete, it will warn you that items are going to be deleted. If you are get this message, hit cancel and move on to the next one.
An alternative would be to use something like Dynamo or and add-in that could check for items associated to a specific level.
One example may be this post.
https://forum.dynamobim.com/t/items-by-level-regardless-if-they-occur-or-not/8840/8?u=seanp
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
What about using a Schedule to assist you?
Thanks! I created a custom member schedule that listed their levels. That was a good idea, perfect!
