Hiding Triangle Edges on Surface
semih.topcu94
semih.topcu94
Hi. I am new in Revit. I wanna hide to triangle edges on surface. I can hide in shaded visual style but I wanna do this in hidden lines visual style.This surfaces import from rhino.(on 3d dwg) See below for screen shot. Any help appreciated. Thanks!
RevitRx
If it is a dwg, you can control the layer visibility and that's about it... coming from rhino, not sure how your layers have been translated. Use the query tool to click on any of the imported/linked lines:
or, in Visibility Graphics you can also control the layer visibility:
Hopefully you have layers that you can control, otherwise you'll need to clean up your layers in AutoCAD.
Hope this helps!
www.RevitRx.com
Are you talking about Triangulation Edges on a Toposurface?
or this?
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/R...
semih.topcu94
I want to only red lines on this photo. I want to clean others. It's painted by me.
Do this:
Copy and paste the address inbetween the parenthesis into your browser. Link ain't working for some reason.
(      https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/R...     )
https://
knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/Removing-lines-of-imported-3D-geometry
.html
