Hiding Floor Pattern for Concrete
Message 1 of 10
I have created my model, and have placed the floor assembly in.  It is concrete and I see the concrete pattern on the floor.  How do I hide or turn that off?  I cannot find anything in Visibility Graphics or in the actual floor family...
Thanks...
-Frustrated (Dave)
Replies (9)
Message 2 of 10
Under Floor Model Category in VG, click Override Pattern, then turn off pattern display.
See attached.
cheers
Message 3 of 10
AHHH!  Thanks - My problem was that I was tweaking the sub categories of the Floor - now I get it - Thanks!
Message 4 of 10
what if i want to only hide concrete patterns and leave the other materials visible?
Message 5 of 10
davidtetro
Select the item you want to hide the pattern, Right-Click and select Override Graphics In View > By Element and then select either Surface Pattern or Cut Pattern and turn them off (depending on if the item is in section or plan/elevation.
Message 6 of 10
CoreyDaun
Create a View Filter that applies to the Floors Category, set the Filter Rules to "Type Name" "Contains" "concrete" (assuming that "concrete" appears in the Floor Type's name), add this View Filter to your View(s), and turn off the Surface Pattern display in the same way as described in post #2 above (except in the 'Filters' tab).
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 7 of 10
cheers guys
Message 8 of 10
You can also right click on the element (Concrete floor) and make sure you have selected "Make the elements editable" . Then right click and go to "Override Graphics in View" > By Elements . On View-Specific Element Graphics > Surface Patterns> Uncheck Visible.
Good Luck,
Message 9 of 10
Thanks man!
Message 10 of 10
JBooneU6H9R
Community Visitor
Community Visitor
Cut and projection section under floors.  make sure all patterns are turned to not visible.
