04:08 AM
- Mute
- Permalink
- Report
I am working on a project which is going to have fused Glass reinforced plastic panels for the façade and I wanted to know if there is a way I can mimic the same using a curtain walls. I have a used a curtain wall system for a couple of reasons the first being I have a pattern of the façade which is split into modules thus I could not make a continues panel, secondly I needed to bound the rooms to the exterior wall.
what I have current in the model is a curtain wall system with a set panel size and the façade is shaped like a cuboid with rounded corners. I have attached a snapshot of one of the corners.
thank you in advance.
