Hiding Boundary Line of Slab
Message 1 of 8
Is there an easy way to hide a boundary line of slab in my plan view. I've tried using my VG to override the slab lines but they still appear and in some cases they are not shown on my plans, but they will plot out. This isn't a slab that i created, its from a vendor who created sections of slab rather than a complete overall slab. Thank you
Replies (7)
Message 2 of 8
Use Linework tool to change the lines to Invisible.
Message 3 of 8
I need to do this on 100 floors, is there an easy way to select them and change, or do i have to do it one by one?
Message 4 of 8
No, Linework tool needs to pick line by line, view by view. What if you hide the slabs altogether? Do you need to show their surface pattern or what?
Message 5 of 8
yes i need to show the surface area and the outside boundary line.
Message 6 of 8
Is still not letting me modify the boundary line and set the line type to invisible as you can see in this picture.
Message 7 of 8
You cannot do that by editing the boundary. Close out editing mode. Click on Linework tool from the Modify ribbon panel, select Invisible line from the list, then start picking lines of tge slab, one by one.
Message 8 of 8
AMengineeringWPG62
-Select floor/slab then
-Go to Visibility Graphics "VG"
-Select and expand Floors Category
--Select and Turn off Folding Lines
